Sanyo Z1 Light blob on dark images
Discussion in 'Projectors, Screens & Video Processors' started by rfraser, May 8, 2003.
  1. rfraser
    rfraser
    I have a new Sanyo Z1 projector which is a couple of months old.
    On dark images - or when the "no show" button is pressed, a circular blob of slightly lighter area (with a greenish tint) is visible on the screen. This is static and about 5 inches in diameter - the screen is 6 foot in width.
    (located to right of screen about 1/3 of distance from bottom.
    The appearance of this has occurred subsequent to initial use.
    Can anyone explain what might be causing this.
  2. -Jay-
    -Jay-
    Jul 26, 2002
    4,934
    Kop End
    +135
    I new to this but have read things like this before, i think it might be a dust blob :(
    i might be wrong but thats what it sounds like.
  3. Underscore
    Underscore
    I've got exactly the same thing, except my blob is blue. I'm assuming that it is a dust blob as well - though I'm a little confused that it only shows on dark images. At the moment, it's not noticable enough for me to open the PJ up or get Sanyo to service it - but if you decide to do something about it, I would be very interested to hear of your experiences.
    Cheers,
    _
  4. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    sounds like dust if its green its on the green panel and if its blue its on the blue panel. I dont know how easy it is to clean the panels on a z1 but i have cleaned them twice on my ptae100 and its very easy to do and only toook 10 mins
  5. Amrik
    Amrik
    Jan 7, 2003
    288
    28
    Sutton Coldfield
    +36
    underscore..
    Exactly same problem as yours on my Z1...only about 30hrs use!
  6. rfraser
    rfraser
    I found some info from a chap who'd cleaned his Z1.
    I followed his instructions (having worked up the nerve to do it and having got really fed up with the blob!)
    I removed the 6 screws on the underside of the case, then, having turned the projector right way up, removed the top cover.
    Behind the lens there are 3 rectangular openings. Each of these has a gold ribbon cable across the top. This is where the lcd panels are located.
    I used an air duster (Kenair Air Dust Kit bought from Jessops for £10.99 - basically just an aerosel of compressed air with valve) to remove the dust. I put the projector on its side near the edge of the table. This allowed me to keep the air can upright (essential). I then blasted air into each of the openings. Afterwards I reassembled the case.
    In fact I had to do this twice. It did not work the first time. The second time I was less hesitent and sprayed the air for longer, with the outlet closer to the lcd panels. The blob is now gone.
    The whole proces takes about 15 minutes.
    Do not mark the screws and it should not be obvious the case was ever opened (avoiding warrenty problems).
  7. rfraser
    rfraser
    If I have got attaching a file correct this is a picture of the projector with the case off. Note that there is a cable running from the main circuit board to the controls on the lid (be careful not to stress).
