Sanyo Tech Support NEEDED!
Discussion in 'Projectors, Screens & Video Processors' started by springfieldict, Jun 7, 2005.
  1. springfieldict
    springfieldict
    Right,
    I have a Sanyo PLC-SW15 (PRO-X) PJ that is not responding at all, ie, no lights, fans, anything. I have reset the thermal trip inside, replaced the lamp, cleaned filters, opened her up but it looks fine inside, pressed the reset button on the case, everything.
    It's just over 3 years old. Has it had it's day? It was working fine up until the point it just turned itself off! Someone please help before I throw her in the bin. :thumbsdow
    Thank You.
  2. Maff et1
    Maff et1
    Sure the power cable is OK?
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
    are you in the UK?
  4. cyberheater
    cyberheater
    Apr 3, 2003
    3,200
    Scotland
    +178
    How did it stop working. Was it working fine and then you switched it off and then the next time it didn't switch on or did it fail whilst projecting.
  5. springfieldict
    springfieldict
    The Power cable is fine as I have checked several, the socket itself seems fine ie; there are no obvious breaks from the board.
    I believe it was turned off at night and wouldn't turn back on.
    And yes I'm in the UK.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,294
    +1,217
  7. springfieldict
    springfieldict
    Thanks, I'll give them a try
    The same thing happened before and we sent it back to Sanyo as it was still under warranty and they said all they had to do was 'reset' it. I thought that would be the thermal trip.
  8. Maff et1
    Maff et1
