Sanyo Projector Lamp Hours Reset using Keys
Discussion in 'Projectors, Screens & Video Processors' started by umarbs, Dec 25, 2006.
  1. umarbs
    umarbs
    Does anyone how I can reset my sanyo XU35 Projector's lamp hours using the keys on the top of the unit? My projector does not come out of standby mode for some reason. I checked the lamp and it still looks good. I believe I can solve this problem by resetting the lamp hours but I cant get into onscreen menus as the projector does not turn ON.
  2. ijd
    ijd
    May 20, 2005
    2,172
    63
    +126
    if the bulb is close to the end of its life it should be changed, just resetting the clock can do more harm than good,it should stop the lamp before it blows, serious damage can occur if this is allowed to happen. that is why they have the clock in the first place.
  3. paul1967
    paul1967
    Dec 26, 2005
    1,258
    48
    +65
    I would say the lamps blown , thats what happened to mine , went to bed 1 night came down in the morning and it would not start up , my bulb looked ok but had like a film on the lens and on the reflector, I was told this was from the gas leaking.
  4. umarbs
    umarbs
    I just dont wanna buy a new lamp when there might be something wrong with the projector. The bulb has not been used a lot and I see no reason for the projector to go to standby mode. I'm hoping its something to do with the bulb. Any help would be appreciated.
  5. paul1967
    paul1967
    Dec 26, 2005
    1,258
    48
    +65
    How many hrs my Z4 only did 600 :thumbsdow
