Sanyo PLVZ2 => cannot reach maxi resolution (dvi+shuttle)
J
julienb
Hello !!
- I use a Shuttle sn41g2 v2 (it contains a NVIDIA GeForce2 chipset) with a cv22 DVI AGP Card.
- My OS is XP Pro sp2
- I have a Sanyo PLV Z2
I have some problems :?
I use a Nvidia Driver (66.93, the latest)
I put "Auto mode selection" for Full Screen playing in settings panel.
The best mode is to use DualView ... I think.
I have a lcd (main monitor, 1024x768,60Hz)
I want to use my PLVZ2 at the maxi resolution (1280x720)
I did these tests:
A**** Sanyo is the secondary monitor!
1/ play a HD 1280x720p file
ok, Sanyo plays .... but at D-SVGA (800x600)
If I use the 4:3Normal screen, i just have a little image :(
I must Zoom to fill my screen :x
2/ play a DVD
Seems to be OK ... of course, comparated to HD, DVD is poor format:
800x600 + zoom is enough
B**** Sanyo is the main monitor!
I succeeded in creating a custom settings in NVIDIA but... all darkest parts of picture seems to be "in the matrix ;) " => little green lines are blinking !
I went to these links:
- http://www.entechtaiwan.net/forums/viewtopic.php?t=267
- http://entechtaiwan.net/forums/viewtopic.php?t=459
Ok, I use powerstrip ; but My Sanyo seems to try D-XGA and .... fall again & again in D-SVGA
MonInfo gives me a strange result :
3 Monitors :
1 Nvidia...GPU
1 Nvidia...GPU2
1 Sanyo
Did someone already see these phenomenon ?
Did you find a solution ?
Powerstrip is a layer over Nvidia.
Which one do I customize ? Powerstrip? Nvidia ? nvidia first ?
I'm losing my mind ....
Anyway, I can use my Z2 but I cannot sleep quietly because I know that it can do better ;) ;)
If someone could guide me ... it should be great :)
SeeU!
JulienB
nb: If I succeed, I write all my settings in a post in order the others could read it and never become craziest than me :!:
J
julienb
My LCD Screen cannot reach this resolution :(
But no problem
I used Powerstrip in order to customizes my settings => Ok => Now,I can send 1280x720 to my Sanyo Z2 :clap:
I configured my Card as "DualView"
I just only have a last problem :
I succeeded in creating a custom settings in NVIDIA but... all darkest parts of picture seems to be "in the matrix " => little green lines are blinking ! :eek:
to be continue...
V
Voidy
Maybe your having the same problem i had.
Is your projector recieving analog or digital DVI input?
Nvidia drivers have a problem at the moment when running DVI digital, in which they can only select the EDID resolutions, which all happen to be 4:3. A work around i found was to turn off my machine, use a DVI to VGA adapter with my CRT plugged in. This forces the card to run in analog.
After windows has loaded, i unplug the crt and adapter, and plug in the projector over DVI, then i can pick whatever resolution i like. [email protected] works perfectly, no need for powerstrip etc.
Hopifully that helps some.
EDIT : now that i think of it, anything using a geforce2 chip is prolly analog anyhow. I guess that would be why powerstrip worked without forcing a virtual desktop.
LG CX 4K OLED TV Review: The best TV of 2020?
