Sanyo PLV-Z3 Fuse Required?
Discussion in 'LCD & LED LCD TVs Forum' started by EnglishJohn, May 11, 2005.
Tags:
  1. EnglishJohn
    EnglishJohn
    May 1, 2001
    253
    Suffolk
    +6
    Hi there mr postman has just delivered the projector - wife is downstairs and i still have not told her :suicide:
    Anyway the plug is missing so i need to no what rating fuse to put in it 13amp? - someone help!.
    Cheers. John
  2. SteveW70
    SteveW70
    Think you're in the wrong forum but according to the spec it has a power consumption of 210w which equates to less than 1 amp !!!
    Stick a 3amp fuse in and see what happens ;)
    You'll only blow the fuse :smashin:
