Sanyo PLV-Z2 Bulb Usage
Discussion in 'Projectors, Screens & Video Processors' started by cliocarl, Jun 6, 2004.
  1. cliocarl
    cliocarl
    Mar 27, 2004
    337
    Cheshire
    +4
    How do I check how many hours are on the bulb?
  2. inzaman
    inzaman
    Dec 16, 2002
    7,991
    Derby
    +1,051
    Whilst the projector is actually switched on so you have an image you press and hold down the power button on top of the projector for about 30 seconds or so. Then in the top left hand corner it will show the usuage in both eco made and full mode.
  3. cliocarl
    cliocarl
    Mar 27, 2004
    337
    Cheshire
    +4
    Thanks will try this once its up and running
  4. cliocarl
    cliocarl
    Mar 27, 2004
    337
    Cheshire
    +4
    It works! Cheers I have just bought one with 214hrs on clock
