Sanyo PLV Z1 help
Discussion in 'Projectors, Screens & Video Processors' started by Sarah T, Jul 31, 2004.
  1. Sarah T
    Sarah T
    Hi everyone I'm new here.
    I have just bought a Sanyo PLV Z1 projector. We've set it up to try it out and it works fine but is playing in black and white. It has come from the US and I'm in the UK. Which settings do I have to change? I was fiddling around with it yesterday and got the colour working but I can't for the life in me remember how I did it. Any help would be greatly appreciated!
    Thank you :thumbsup:
    Sarah
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    set it to PAL if using UK DVD TV etc or set to auto, US use NTAS which has different colour info!
    Also what connection are you using?
  3. Sarah T
    Sarah T
    I think it's now set to PAL. The connection is Y,Pb/Cb,Pr/Cr.
    Still no colour though.
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    what are you sending to the PJ and from what???
  5. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    If you're getting a black and white image from component connections the chances are that the source you've got it connected to is not set to output component video, or there's a fault with the lead. Check both and you'll get it working fine.
    Sean G.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    i cant remember if there is a 50/60 Hz setting try swapping around if there is. Are you using a step down transformer or just a standard poer lead?
  7. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    The Z1 will work on any voltage between 100 and 240 at 50/60Hz.
    There's an auto signal position in the menu that accepts both PAL and NTSC.
    Jeff :rtfm:
  8. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    My money is still on an incorrectly set source or the lead................ :hiya:
    Sean.
  9. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Mine too, sean. A b/w image is displayed by the 'y' connection of component, and you would get the same if you connected the y to composite video input on the PJ, or the composite output of the source to the y input of the PJ, so either leads in the wrong place or a loose plug on the component cable is the most likely problem.
  10. Sarah T
    Sarah T
    Thanks everyone. I started all over again and it seems one of the wires was in the wrong place. It's now working fine. :smashin:
    Thank you!
