Sanyo PLV-Z1 fan speed?
Discussion in 'Projectors, Screens & Video Processors' started by Gee, Apr 13, 2004.
  1. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    Do the fans on the Z1 normally speed up and slow down when it's being used in theatre black mode?
    Thanks,
  2. ShortNick
    ShortNick
    Jul 26, 2000
    176
    +6
    Thought mine was doing it the other day but it turned out to be the fan on my PC, which I had inadvertently left switched on! Had me worried for a while, could it be anything else in your room? I always run mine on half bulb brightness, much quieter.
  3. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
    Mine's speed becomes inconsistant when the room heats up - speeding up and slowing down every few seconds. There's a service tweak that might fix it but I haven't got round to trying yet.
  4. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    Thats exactly what mine seems to be doing. Once the room heats up a bit the fan speed increases and descreases most of the time. What do you know about this service tweak?
    Thanks,
  5. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
    Here's a post from the AVSForum in the states. Not sure if it's the same problem though...
  6. Gee
    Gee
    Jan 24, 2001
    204
    Stockport
    +5
    I'll give that a try. What is the url for the AVS forums?
  7. calscot
    calscot
    Oct 29, 2002
    665
    16
    Milton Keynes
  8. creative-av
    creative-av
    Aug 30, 2003
    1,093
    48
    +56
    Does anyone know if this is the same for the Z2?
