Sanyo PLV-Z1 builb
burpfish
Anyone a pointer on where to get a cheap and reliable bulb for this projector?
Or, failing that, a good thing to do with a bulbless projector?
Thanks!
Jazz Monkey Jr
lol, I emailed Sanyo today hoping to get a free bulb for the Z4 :) (see Projector Lamp Warranty - SANYO EMEA)
Failing that I find you can get pretty good bulbs on ebay although am not entirely sure what bulb for the Z1 (though the listing might show that)
I have just bought a second hand Z4, can you get a free lamp?
burpfish
Thanks for that guys ... the only problem now is, the bulb is worth more than the projector. It may be time to upgrade ...
greigym
Chaps - if you can get a bare bulb for it then go for it. Have a look on youtube for instructions on what to do under "bare bulb". Ebay can be a mine field....only buy in the UK as imports from abroad are bound to be copies!
