Sanyo PLV-Z1 arrived. Set up tips required
Discussion in 'Projectors, Screens & Video Processors' started by jtorry, Jan 10, 2003.
  1. jtorry
    jtorry
    Nov 8, 2001
    520
    Hi the projector arrived today and I would just like to ask a few questions on setting up. I am running a HTPC for dvd playback and am having some trouble setting custom resolutions in powerstrip. I set the resolution to 967x544 (I said 966 but powerstrip changed it) as this is the res of the projector. The problem is that it cuts off some of the screen at the right hand side. I also am unsure as to what aspect to set the custom res to. Any help would be apreciated.
  2. jtorry
    jtorry
    Nov 8, 2001
    520
    I have also just noticed a large green circle shape that is on the right middle of the image. Any ideas what this is and how to get rid of it?
  3. theritz
    theritz
    Aug 17, 2002
    2,451
    Ireland
    +27
    Post deleted.
    Sean G.
  4. stevelup
    stevelup
    Aug 13, 2002
    6,142
    Swindon
    +855
    If you completely defocus your projector, you might be able to see the marks more clearly.
    A colleague of mine had exactly this problem and was told to return his projector to Sanyo for replacement. I believe someone else on this group has reported the same problem.
    Steve
  5. jtorry
    jtorry
    Nov 8, 2001
    520
    Yes. I think it is a dust spot. You can apparantly easily remove them using some compressed air, but you have to remove the lid to do this.
  6. spamboy
    spamboy
    From a previous post:
    Headrat,
    The Sanyo Z1 settings are:
    Input Mode (?) : FULL or TRUE
    Fine Sync: 1-31 adjust for a stable picture
    Total Dots: 1104
    Horizontal: 129
    Vertical: 21
    Generic timing details for 960x540:
    HFP=16 HSW=32 HBP=96 kHz=34 VFP=2 VSW=6 VBP=15 Hz=60
    Julia
  7. jtorry
    jtorry
    Nov 8, 2001
    520
    Thanks.
