sanyo plc-30sw and component?
Discussion in 'Projectors, Screens & Video Processors' started by ajwoodhouse, Nov 9, 2004.
  1. ajwoodhouse
    ajwoodhouse
    Just bought a Sanyo plc-30sw projector for a bargain price (OK not great but should be better than my 28" samsung TV!) and am trying to find a VGA to component cable for a reasonable price...any ideas? And is it worth it over s-video?
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
  3. ajwoodhouse
    ajwoodhouse
    Thanks...did more googling and bought a 5m cable from Keene Electronics :thumbsup:
    (Why a VGA to component convertor rather than HD15 to component cable...would it be better?)
  4. MikeK
    MikeK
    Oct 9, 2004
    2,231
    83
    +316
    A VGA output port (on a computer for instance) does not output component video, it's RGB video with H&S sync - so to get component video from such a port, you use a VGA to component video converter.
    That's a little different to what you want (have bought), where you are using the HD15 (or VGA) input port on the projector to input component video from a DVD player's component video outputs (usually 3 phono connectors). The PJ can be setup in the menus to accept either component video or RGB video on it's VGA input port.
    At least I think that's what you're asking :)
  5. ajwoodhouse
    ajwoodhouse
    MikeK,
    My Denon 2200 outputs component video via 3xRCAs.
    My projector has a VGA connector for component.
    I think you got it right - I don't plan to use a computer with the projector (yet) :D
