Sanyo DVD-9201 Hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by is1111, May 7, 2005.
  1. is1111
    is1111
    Mar 17, 2005
    1,278
    48
    +98
    Hi does anyone know if it is possible to make the Sanyo DVD-9201 region free with a hack of some sort?
    any info would be greatly appreciated.
    cheers
  2. is1111
    is1111
    Mar 17, 2005
    1,278
    48
    +98
    hi think i have managed to make my machine region free. after searching around a bit found that there is a disc that unlocks the 7201 model but will also work on the 9201.
    after more searching found somewhere to get hold of the image and put it on a cd. followed the instructions and appears to have updated my player. my region 1 blade trinity is due in next couple of days so i will test it out and let you know if it worked.
    cheers
