Sanyo DC-TS760 sound question
Discussion in 'Blu-ray & DVD Players & Recorders' started by Yellow, Dec 2, 2003.
  1. Yellow
    Yellow
    Hi Folks,
    I am new to the board so forgive me if my question is stupid. Just bought a Sanyo DC-TS760 home cinema package and have a problem with the background humming noise it makes when it is switched on. It is really noticeable at quite points in a film, if the dialog stops you hear this constant mechanical whirring/humming noise in the background. This is my first dvd system so my question(s) are, do all home cinema systems put out this type of noise or has anyone else bought this particular system and noticed the problem and if so can anyone suggest any solution to this?
    Regards,
    Chris
