K
kyzer
Anyone got a remote hack for a sanyo dc-ts 750? (Multi-region)
Kyzer:
Kyzer:
bobgriffiths said:Its a firmware hack that you burn on to a disc.
I'm trying to find it for you but dont pin your hopes on it.
By the way this hack will not make the machine play VCD or SVCD there is no hack that will on this unit.
By the way this hack will not mak :e the machine play VCD or SVCD there is no hack that will on this unit.
I have never done this hack so I dont know if it is 100% about 10 people said it worked BUT one person said he lost all video!! But he was from another region than UK.I take no responsibilty for any consequencys from trying this hack.
1st Down load the DVDSL20.zip Zip file below this apparently works on The Sanyo DC-TS 750 this will NOT work the 760
2nd Read the readme file
3rd Burn the correct san file as per the instructions to a CDR
4th Turn on the DVD player, insert the disc and close the tray. DON'T TOUCH ANY BUTTONS! Now start to pray!
Picture will go snowy, this is normal. After about 30-40 seconds, DVD will go into
Standby, turn back on and you have a multi-region player .
Region code hack posted by Hans Laungeville at January 26 2003:
You can the hacks for both the UK and UK2 version of the SL-20 from my website:
http://members.lycos.co.uk/brobert99/Programs/
The DVDSL20.zip for the UK version (must be unzipped)
and DVDSL202.san for the UK2 version
please let us know if this works
