Sanyo countdown problem
Discussion in 'General TV Discussions Forum' started by raydawson, May 11, 2005.
  1. raydawson
    raydawson
    Nov 26, 2004
    232
    28
    UK
    +27
    My son has a 32 inch Sanyo - possibly the 32WN7 - and it's developed a strange problem.
    If he tries to select a TV channel, he gets a countdown box counting down from 10. After 10 minutes the TV turns off.
    Using the AV input, there's no problem.
    It isn't the sleep timer as that is turned off. He's searched the menus for any other timer function, but no joy.
    Any ideas anyone please?
    Cheers,
    Ray D
  2. nig28
    nig28
    Some TV's do this if there is no aerial lead connected!!
    Nigel
  3. JayCee
    JayCee
    Jan 20, 2004
    22,404
    Lanarkshire
    +2,346
    As nig28 says if there is no signal present, the set will go into automatic switchoff.
    You didn't say if the terrestrial channels were tuned in.
  4. raydawson
    raydawson
    Nov 26, 2004
    232
    28
    UK
    +27
    Thanks for the responses. I've pointed my son at this thread so he can read your advice.
    Cheers,
    Ray D
