Sansui turntable
Discussion in 'Hi-Fi Stereo Systems & Separates' started by M0T, Jul 16, 2003.
  1. M0T
    M0T
    Jan 27, 2002
    141
    +5
    I tried to use this but unfortuneatly the bloody belts slipped off and I have not a clue how it goes on. Any ideas?
    Picture of the belt area below
    [​IMG]
  2. keiths
    keiths
    Nov 19, 2002
    168
    Derbyshire, UK
    Just guessing, but I would have thought that the belt goes round something inside the platter and then gets looped round the brass pulley (upper left on your pictue) and through the 'hook' on the end of the speed-change arm just below the pulley. You would do this through a hole in the platter (under the mat).
    As I say, only guessing though.
  3. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,896
    71
    50 Rue St Georges, Paris.
    +27
    As above, but also just a guess, are you trying to fit a new belt, if not the old belt has probably stretched causing it to slip off.
