Sandisk Pro-duo and Sandisk Gaming Pro-Duo. Difference?
Discussion in 'PS Vita Forum' started by UKbondraider, Sep 1, 2005.
Tags:
  1. UKbondraider
    UKbondraider
    Oct 30, 2004
    699
    +9
    anyone know what the differences are if any with the Gaming Pro Duo memory cards that Sandisk sell compared to their normal pro-duo cards?
    The gaming cards are yellow in colour and are always slightly cheaper than the normal blue coloured memory stick. Is the cheaper price reflective of certain limitations?
  2. lurcher
    lurcher
    May 15, 2003
    4,216
    Stalybridge
    +221
    Yes I was wondering that as well , the only difference I could see in listings was that the yellow game one came without the adapter that allows use of normal memory stick.
  3. Mr Goat
    Mr Goat
    Nov 20, 2003
    2,419
    Southampton
    +108
  4. saeco
    saeco
    Jul 3, 2005
    2,035
    London
    +24
    I did search b4 for this .... a guy in forum said he did called to sandisk and they said both of the card uses the same technology and they are identical ... the yellow transparent plastic are for marketing purposes. The price for both of the card are same as well ... just that the normal blue come together with MS adapter.
