sandisk 4gb usb drive problems..
Discussion in 'Computer Peripherals & Consumables' started by fender87, Jan 31, 2009.
  1. fender87
    fender87
    May 27, 2008
    7
    Hey,
    I have a Sandisk usb drive, problem is i have deleted data off it yet it still sees the space as used it says 3.4gb used when i only have some word files on it as i deleted the music and movies off it.
    i havent got a clue how to fix it and would appreciate some help thx.
  2. Extasy
    Extasy
    Apr 29, 2008
    32
    +5
    try to format memcard in differenet file system.
  3. graham.myers
    graham.myers
    Mar 11, 2003
    6,228
    Leeds
    +931
    I've had this before and copying off needed data, reformatting cures the problem.
