SanDisk 1GB Memory Stick Pro Duo
Discussion in 'PS Vita Forum' started by tregoni, Oct 20, 2005.
Tags:
  1. tregoni
    tregoni
    Nov 4, 2004
    24
    Does anyone know what the differece is between the SanDisk 1GB Memory Stick Pro Duo (Gaming) card and the SanDisk 1GB Memory Stick Pro Duo Card?
  2. bellso
    bellso
    Apr 21, 2004
    1,487
    Leeds, U.K.
    +330
    Nothing really. Sandisc is actually supposed to be faster than the Sony one though, so get over Sony if u can.
  3. tregoni
    tregoni
    Nov 4, 2004
    24
    Thanks, Sandisk appears to be cheaper than Sony anyway, and I think Sandisk actually make the cards for Sony
  4. kez
    kez
    Jan 18, 2002
    8,435
    Leeds, West Yorkshire
    +1,405
    the gaming ones are different coloured (depending on size) and don't come with the adapter to allow you to use them with a non-duo device
  5. bellso
    bellso
    Apr 21, 2004
    1,487
    Leeds, U.K.
    +330
  6. Jaymzee
    Jaymzee
    Feb 28, 2005
    615
    Aberdeen
    +58
    For anyone who's interested,i just saw my local GAME store selling the 1 Gig Sandisk Cards for £74.99, which is cheaper than every other highstreet store selling them at £99.99!!
  7. peb
    peb
    Mar 18, 2003
    28
    3
    I had ordered the 1GB gaming stick but was sent the normal pro duo, so I e-mailed SanDisk to determine whether or not to accept it. They replied telling me to return it and purchase the correct gaming memory. They did not explain why or what the difference is but obviously the gaming stick must be more suitable for the PSP or they would have told me to keep the other one.
  8. bellso
    bellso
    Apr 21, 2004
    1,487
    Leeds, U.K.
    +330
    Have been told that the gaming ones are quicker for downloading to, which might be true as i have the standard stick and it does take an age to load anything on it.
    Anyone know if there are usb2.0 cables available and if this would speed the process up?? [not sure if PSP is usb2 compatible??]
  9. welshboy
    welshboy
    Jan 6, 2005
    620
    Swansea
  10. bellso
    bellso
    Apr 21, 2004
    1,487
    Leeds, U.K.
    +330
    People on another forum have bought from them and were fine.
    I have this stick [but bought from neodisc.com], and apart from my comment above about the slow-ish write times, can't fault it, and would rather save £20 than pay high street prices.
  11. matt bellamy
    matt bellamy
    Jun 19, 2004
    230
    16
    I just found somewhrere that sells them for £43 + £2 recorded delivery (see here ). I've never bought from them before but there's a store review here .
  12. monkeyspank
    monkeyspank
    Feb 17, 2005
    160
  13. Forestred
    Forestred
    Oct 2, 2003
    297
    Norwich
    +6
    Yes the PSP is 2.0 compatible and the cable will make a big difference, with a USB 1 cable 280mb typicaly takes 7 minutes to transfer but with USB 2.0 it takes 2min.
    A point to note is that it is supposed to be even faster if you use a card reader!
  14. bellso
    bellso
    Apr 21, 2004
    1,487
    Leeds, U.K.
    +330
    Cheers, gonna hunt out a usb2 card reader then
