Sand...
Discussion in 'Home Cinema Speakers' started by Bobby, Dec 19, 2000.
  1. Bobby
    Bobby
    No get outta the play pit, I mean the stuff you fill speaker stands with [​IMG]
    I'd assume the best is sand thats obviously not damp to prevent corrosion of your stands but where can you buy it?, is it a special kind? do you have to dry it out yourself in the oven? [​IMG] I've looked at the special metal stuff some companies sell but it's just too darn expensive for what it is, someone point me in the right direction please.
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    The recommended material to fill the stands with, from B&W so i've heard, is the clay cat litter stuff. Dunno why, but seems sensible...
    I'm NOT joking!
    Rick
    'I am just a figment of your imagination.'
    MiB 1997
    Work Site: The Sound Gallery
    Home Site: WD A.V.
  3. dUnKle
    dUnKle
    Jan 1, 2001
    15,274
    +2,278
    Use normal sand but bake it slowly on a low heat in the oven for about an hour
  4. Bapapapa
    Bapapapa
    Jul 24, 2000
    113
    16
    As bizarre as Duncan's reply sounds, that is exactly what I did. I bought some play-pit sand & was worried aboutit being slightly damp and stuck it in the oven. Missus was not chuffed when she found out. [​IMG]
  5. Bobby
    Bobby
    Cheers guys, don't have a cooker yet as I've just moved into a new house, maybe I can put it in the microwave [​IMG]
  6. ThunderSUB
    ThunderSUB
    Hi guys,
    I bought a pair of Target FS60 stands and another pair of Target MX100 stands. I also wanted to fill them. I asked the Portuguese importer of Target if they sold the Target "Heavy Metal" sand. As they didn't, they told me to buy "sand with no salt" (I am sure there's a correct english word for this but I can't remember it...).
    So, I bought the "sand with no salt" at the local pet shop and put it in the oven...
    I have B&W speakers.
    Claudio Subtil
    Lisbon, Portugal
    http://drive.to/thundersub
  7. Guest
    Try kids sand from somewhere like Toys R Us,
    It shouldn't require any messing as it's dry sand for little sprog sand pits !!
  8. General Skanky
    General Skanky
    Jul 28, 2000
    4,247
    71
    +43
    Just go to somewhere like Wickes or Homebase etc, you can buy kiln dried sand for about £2 a bag. Just put it straight into your stands. You'll only need 2 bags at most.
    Hello, Duncan.
    Been a while.
    Douch!!......Wot's da madder, da CIA got you pushing too many penzils?
    Work: www.hughes-tv.co.uk
    [This message has been edited by General Skanky (edited 20-12-2000).]
  9. Bobby
    Bobby
    It's a shame you can't buy clear speaker stands made of toughened perspex, you could make something like the THX logo in different colours [​IMG]
  10. dUnKle
    dUnKle
    Jan 1, 2001
    15,274
    +2,278
    The no salt thing is so it does not corode the stand but you should find that baking it will prevent this anyway.
    Also if you have a large space inside your stand you can always put the sand into a plastic bag or something similar first.
    Im glad to be back and glad to have been missed
  11. Bobby
    Bobby
    Well the speaker stands arrived this morning and after unpacking them it seems they are provided with quite strong plastic bags which go inside the holes at the bottom, are filled, tied up, then the base screwed on so not much of a problem anyways [​IMG]
