sand for stands
Discussion in 'Home Cinema Speakers' started by carter, Apr 1, 2003.
  1. carter
    carter
    I've just bought mission stance speaker stands for my B&W 601S3 and want to sand fill them. I have bought play pit sand from homebase and have baked this in the oven to futher dry it. It is now very dry and fine.
    Is this still likely to absorb moisture over time and rust my stands?
    Using stands on carpet and floor spikes don't quite penetrate carpet - any tips, such as marble floor tiles etc? or should I just force them right through carpet onto the concrete
    Also any recommendations/advantages for using supplied top spikes - currently using blue tack instead
    chars
  2. nathan_silly
    nathan_silly
    Mix in silica balls with the sand, as they absorb moisture (same stuff you get in them little packs)
  3. carter
    carter
    where is best place to find these?
  4. bob1
    bob1
    Nov 7, 2002
    4,326
    Sheffield
    +129
    Wilkinsons sell moisture absorbing crystals or balls.
  5. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    B&Q and other places like Focus sell kiln dried sand, only about 2 quid a bag.
