Samung LCD TV RF input
Discussion in 'LCD & LED LCD TVs Forum' started by rags, Nov 21, 2003.
Tags:
  1. rags
    rags
    Apr 13, 2003
    4,089
    London
    +323
    HI all - I just picked up a 15 inch Samsung LCD screen. The problem is the room I want to use it in only has an RF lead (normal TV aerial feed) in it but the Samsung only has inputs for scart, composite and S video - is there any way I can connect the two together ?
    The RF aerial lead is coming from the loft via an amplifier and is carrying both terrestrial analogue tv channels as well as sky.
  2. hOwLa
    hOwLa
    RF feed is the worst u can put into the LCD, is there no way u can run SVideo cable from the loft?
  3. rags
    rags
    Apr 13, 2003
    4,089
    London
    +323
    No unfortunately it's all wired up and ready to go. It's a good amp in the loft so the signal is pretty good for RF.
    Is there any way to connect them up ?
  4. hOwLa
    hOwLa
    You could buy a RF to RGB or SVideo convertor, if you search these froums I'm sure you'll find one.
  5. Techno
    Techno
    Nov 20, 2003
    312
    if it's not got RF input then it obviously doesn't have a tuner so only real option without rewiring ia Videosender from SKY, the receiver for which would connect to the screen via scart.
  6. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    What about a freeview box ?
  7. Techno
    Techno
    Nov 20, 2003
    312
    Got it - connect a VCR via RF with the output to LCD via Scart - sorted.
  8. rags
    rags
    Apr 13, 2003
    4,089
    London
    +323
    Problem now sorted - the RF input was hidden underneath a panel at the back - I am ashamed of myself and yes I am a complete muppet :blush:
