Max O'Reilly
- Joined
- Oct 26, 2006
- Messages
- 47
- Reaction score
- 7
- Points
- 6
Does anyone have a clue when the new versions of Samsung's Slimfit CTR HDTV range will be reaching our shores?
The USA got them in April this year.
Surely it can't be long now before we get them as I've noticed the existing Samsung Slimfit TVs have became a bit hard to come by recently.
From reviews I've read it seems that all the geometry problems etc. that have been reported here on the exisiting models appear to have have been rectified.
Not only that the picture is supposed to be even better as well.
Here are the specs of the TXT-3093 (although it says 30", I believe I'm correct when I say that we measure screen size differently in the UK so this would be a 32" here. Correct me if I'm wrong.).
They also have another model (TXT-3092) which is almost identical to the TXT-3093 except it has the speakers at the bottom instead of the side to make the set slightly narrower:
Samsung SlimFit 30" CRT HDTV TXT-3093
30" CRT TV
Series SlimFit
Digital Television Certification: HDTV
TV Tuner: 1x analog, 1x digital
Width: 35.5 in
Depth: 16.3 in
Height: 22.4 in
Weight: 116.8 lbs
(TXT-3092 is the same as the TXT-3093 except for
Dimensions & Weight
Width: 31.3"
Depth: 16.3"
Height: 23.1"
Weight: 119.1 Lbs)
Diagonal Size: 30" widescreen
Technology: CRT
Image Aspect Ratio: 16:9
Progressive Scan: Progressive scanning (line doubling)
Display Menu Language: English, French, Spanish
Comb Filter: 3D-Y/C digital
Invar Shadow Mask: Yes
Color Temperature Control: Yes (Warm1/Warm2/Normal/Cool1/Cool2)
Picture Adjustment: Standard/Dynamic/Movie/Custom
Additional Features: On-screen menu, 3:2 pulldown compensation, channel labeling
Analog TV Tuner: NTSC
Channel Coverage: VHF:2-13, UHF:14-69, Cable:1-125
Digital TV Tuner: ATSC DTV
HDTV Ready: Yes
Analog Video Input Signals: NTSC
Input Video Formats: 480p, 720p, 1080i, 480i
Remote Control Type: infrared
Supported Devices: VCR, cable box, DVD player
Sound Output Mode: Stereo
Surround Mode: Yes
Sound Effects: SRS TruSurround XT
Audio Controls: Equalizer
Equalizer: Yes (5-band)
Speakers Included: 2 speakers
Output Power / Total: 20 Watt
Speaker(s): 2 x right/left channel speaker - built-in - 10 Watt
Connector Type: 2 x HDMI ( 19 pin HDMI Type A ) 1 x composite video/audio input ( RCA phono x 3 ) - rear 1 x composite video/audio input ( RCA phono x 3 ) - side 1 x S-Video input ( 4 pin mini-DIN ) - side 1 x monitor output - rear 2 x component video input
Compliant Standards: Plug and Play
Power Device: Power supply - internal
Voltage Required: AC 120 V ( 60 Hz )
Manufacturer Warranty
Service & Support: 1 year warranty
Service & Support Details: Limited warranty - parts and labor - 1 year
Also here are various links to stuff I've found elsewhere on the web about this set:
Samsung USA
Amazon (US) reviews of TXT-3093
news item
Anyone know anything else?
30" CRT TV
Series SlimFit
Width: 35.5 in
Depth: 16.3 in
Height: 22.4 in
Weight: 116.8 lbs
Dimensions & Weight
Width: 31.3"
Depth: 16.3"
Height: 23.1"
Weight: 119.1 Lbs)
Technology: CRT
HDTV Ready: Yes
Surround Mode: Yes
Samsung USA
news item
— As an Amazon Associate, AVForums earns from qualifying purchases —
