samsung z310r
Discussion in 'Home Cinema Buying & Building' started by pcdee, Feb 8, 2009.
  1. pcdee
    pcdee
    Nov 21, 2006
    16
    Hello all
    I have a problem, my TV has a DVI input so I bought HDMI to DVI cable hoping it will work but no joy.
    SO, at the moment I'm using DVI to componant.......any ideas? Thanks
  2. pcdee
    pcdee
    Nov 21, 2006
    16
    Anyone pleeeeeeese :rolleyes:
  3. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    buy a tv with hdmi in!
    thats one suggestion.
    i figure your problem is no picture? or whats the problem?
    you could either just use component - component, or use the AV video out(yellow jack),to your tv's AV in(yellow input)..but that would be a waste.
    most manufacturers dont recommend DVI anything though..
