Samsung VP - D87 from PC to Video
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by magiles, May 19, 2004.
  1. magiles
    magiles
    How do I get my edited film back on to video.
    My camcorder does not have a DV IN but I think you can buy an interface to record it back onto your camcorder from your PC and then onto video.
    does anyone know what its called and where I can get one and what price it might be
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,440
    Rainham Essex
    +2,470
    These DV-in enablers (sometimes known as 'widgets') are getting more difficault to get as it is getting near impossible to enable the DV inputs on most modern camcorders. It all depends on the make & model of your camcorder as to weather it is possible or not. Let us know the make & model and we will try to find out for you.
    If not then your only other option will be to add a card to the PC that has a TV output.
    Mark.
  3. magiles
    magiles
    Its a Samsung VP-D87i
    Another way is to buy a DVD Burner I suspect
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,440
    Rainham Essex
    +2,470
    I have done a quick internmet search for "DV-in enable" and got back loads of sites that list models that can be enabled, but I did not see your cam listed on any of the ones I checked (about 10). I would therefore think that you are unlucky and your cam can not be enabled. As I said before this is not unusual for newer cam models as the EU are fighting back with heavy fines for makers of cams that can be easily modified.
    It looks like you will either need to get a PC DVD burner or a card with TV out!
    Mark.
