Samsung VGA Help
Discussion in 'Samsung TVs Forum' started by SouthBankWolves, May 8, 2007.
Tags:
  1. SouthBankWolves
    SouthBankWolves
    May 8, 2007
    3
    Hello all , ive benn recomended to post here from the guys over at xbox.com, id just like some help with my samsung HDTV and using a VGA cable to play my 360 on. At the moment im using the component leads that came with the xbox 360 its ok on the tv but alot of people said The official microsoft VGA lead was the best picture you can get when using an HDTV so i went out and bought one after hooking it up to the 360 i found that the colours looked a little washed out on the tv and not as bright and in your face so to speak as the component lead was. The VGA lead suppose to get rid of the jaggis that the component leaves on screen. I would like to try the VGA lead again as most people say this is better option so i wandereing if any one had the correct Tv settings for my tv when using the VGA lead on the 360 i.e colour, contrast, sharpness etc my tv is the samsung LE26R51BD model, many thanks in advance i hope some one may be able to help me. xD
  2. Silver Serpent
    Silver Serpent
    Nov 17, 2006
    2,924
    +415
    When connected via VGA, the only picture settings you can adjust are Contrast and Brightness, and it is, as you say, very much washed out colour wise.
    I personally don't like it for gaming. Component is the only way to go.
  3. DrugstoreCowboy
    DrugstoreCowboy
    Oct 5, 2006
    1,046
    Bedford
    +97
    Before using a Samsung R87 I'd have agreed, however VGA looks amazing on the TV with none of the washed out colours and problems I'd had before.
  4. Silver Serpent
    Silver Serpent
    Nov 17, 2006
    2,924
    +415
    I tried it on an M86 and it's terrible compared to component.
  5. rjtd
    rjtd
    Apr 19, 2007
    104
    You should try now the new VGA options on the Spring update.
  6. J273
    J273
    Aug 8, 2006
    1,521
    Swadlincote
    +31
    Is it better then?
    Ive got a Madcatz cable and an N73 series samsung
    do you think itll be better than component?
  7. marcaass
    marcaass
    Apr 29, 2007
    75
    I have an R88, and currently use Component for my 360.
    Is it worth buying the VGA cable given the result is apparantly washed out colours, or has the spring update solved this?
    Is VGA Better than component?
  8. DrugstoreCowboy
    DrugstoreCowboy
    Oct 5, 2006
    1,046
    Bedford
    +97
    I'd say so yes, especially if the TV can display 1360x768 at 60hz - 1:1 pixel mapping, a few games from Capcom and Ubisoft have tearing over VGA so I'm not going to throw the Component cable away just yet, when it does work it's great.
  9. marcaass
    marcaass
    Apr 29, 2007
    75
    Hi guys
    I have just received my Microsoft VGA Cable, hooked it all up including the Audio cables, and when I switched 360, I got no sound at all.
    Before I complain, are there any settings or adjustments to be made either on the 360 or TV? The Sammy is the R88 32"
  10. oAmadeuso
    oAmadeuso
    Apr 29, 2007
    25
    3
    +3
    The new settings do improve it a lot.
    Change the mode to "expanded" and you'll notice it.
    The madcatz cable is not the best option though.
    Had one of those myself and the picture was not impressive.
    Depending on your screen it might be worth getting the Monster brand cable.
    It's a bit pricy though. Most people seem to be happy with the offical microsoft ones.
    Have you got the sound hooked up to the 3.5mm jack? Thats where the vga gets it's sound from.
  11. marcaass
    marcaass
    Apr 29, 2007
    75
    No, I have plugged both the Red and White cables into the respective "Audio In" sockets on the rear of the Telly.....is that not correct?
  12. Blackbolt360
    Blackbolt360
    Sep 28, 2006
    1,793
    116
    Cheshire
    +794
    Evidently not, thats not the Sound for the VGA. If you look closely at the back of the TV, it has white lines which are boxes connecting everything. The Sound input for the VGA is a single 3.5MM Stereo Jack. The official Xbox 360 VGA Lead comes with an Adapter that converts the two Red and White RCA Phone leads into a Single Stereo Jack that you need.
  13. oAmadeuso
    oAmadeuso
    Apr 29, 2007
    25
    3
    +3
    Thats why theres no sound mate,
    the phone imputs are not for the VGA picture.
    You'll need a phono to 3.5mm cable like this.
  14. marcaass
    marcaass
    Apr 29, 2007
    75
    Nice one, thanks for the help. I'll give it a go tonight.:clap:
