samsung vga 1366*768?
mattg
hello all,
sorry for another samsung post, I know there are many about at the moment.
I have a laptop connected to my screen via the vga output and can only get 1024*768 resolution. All resolutions higher than this are "unsupported" and I get a blue screen come up.
my gfx card is an mobility ati radeon 9600 running on the 5.8 catalyst drivers.
Please could you help with the "timings" I need on powerstrip to force the stated 1366*768?
or a work around using my drivers?
When I clone the screen my normal resolution drops to 1024*768, instead of 1400*1050 which is the laptop's native resolution.
Many thanks,
Matt.
simple instructions would be a massive bonus too :D
EDIT
I Think I have cracked it now!
I set powerstrip to 1368*768 for the second monitor. Then I changed the resolution to the same in my cat driver settings.
Then I used the samsung image auto adjust to gain back the parts of the screen that appeared to be "off of the edge".
hope this works now :D
dbeamish
Not sure I can help but the VGA interface from what I understand supports 1360x768 so use that res instead - you will get 3 pixels either side of the screen which wil lbe blank but from a distance of a couple of feet you won't notice them.
