Samsung upscale dvd choice HELP
Discussion in 'Blu-ray & DVD Players & Recorders' started by JimmyCobra, Jun 6, 2005.
  1. JimmyCobra
    JimmyCobra
    Jun 1, 2005
    233
    OLDHAM
    +8
    Hello
    I need some help with choosing a Samsung HD dvd player.
    I have found a few different model numbers but cant find any in-depth information,on the differences each model has.
    how does the HD850 differ from the HD950 is it just you get extra cables with the HD950,or is it a different chip in the player, also what's the HD945 in relation to the HD950.
    this all seems like a mine field at the moment, the HD850 also comes in HD850/XEU flavour, is this a different mutation or is it a store giving it its full title.
    the dvd player will be connected to an Hitachi 5200 plasma screen using a converter cable from hdmi-dvi
    cheers jimmy
