Samsung ultra slim mount
Discussion in 'Home Cinema Buying & Building' started by Rhyst21, Sep 11, 2012.
  1. Rhyst21
    Rhyst21
    Jul 12, 2011
    11
    Stratford Upon Avon
    Hi guys i just purchased a Samsung ue46es5500 Im just wondering which samsung ultra slim mount i need there are a few,
    wmn2000a
    wmn2000b
    wmn2000bx
    little help please guys
  2. hitchhiker
    hitchhiker
    Aug 26, 2011
    2
    I have a 55es6800 and used another samsung mount similar to the ones you mention a WMN250M. great wall mount, but like most they didn't specify on the website if it was suitable for plasterboard mounting, so if you are going to mount on plasterboard do some research first. The Samsung.co.uk website has a compatibility chart for their mounts on it. It also has a review of mine on there. Hope that helps.
  3. unoparker
    unoparker
    Oct 9, 2012
    12
    I think what you need to get for your tv is the wmn2000bx. I'm 80% sure about it but try to get a second opinion from the website of Samsung. The wall mount needed per model of tv is there or try to check the manual of your tv (I guess it is also indicated there). I hope this helps!
