samsung ue55f8000 Stand length ?
DoogyDawg
Established Member
Has anyone got the total length of the samsung ue55f8000 stand,
Im looking at buying one, but I need to have it mounted on a floor unit, I know its longer than the Tv, but if anyone could measure theirs or tell me, that would be great.
Many thanks
DoogyDawg
Established Member
cheers for that, Im a little worried as I have seen a few reviews where they mention the stand like this..
but then thinking about it, if the unit is for a 50' then it should fit, unless the depth of the unit isnt very much
addarioo
Established Member
I had mine on an ikea besta stand for a while which was 120 cm wide by 39 deep. The width and depth was fine for the tv but I would have preferred an extra 5-10 cm of depth.
Also if your worried about the stability you get some string in the box that you can screw into the top two vesa mounts to tether the tv to the stand.
⭐ Philips OLED908 TV & Musical Fidelity A1 amp reviews + a look at two home cinema speaker packages
Back
