Samsung UE46ES8000 flickering / flashing BBC 3D picture
Discussion in 'General TV Discussions Forum' started by Klanker, Jul 29, 2012.
  1. Klanker
    Klanker
    Jul 29, 2012
    2
    I have an issue with BBC HD 3D content which I believe I'm alone in as I can't find any posts on here with same problem.
    The TV detects 3D and switches to the side by side view - however it also starts to flash / flicker as soon as this switch happens. The 3D content seems to be correct (i.e. a single 3D image) its just the flashing makes it unwatchable.
    Updated to latest firmware (10.14) which made no difference. Issue is the same on freesat and freeview. Tried various changes to picture and 3D settings but nothing stops it.
    I've posted a video of the problem on youtube - this shows the flashing for all of the 3D modes (with side by side producing a correct single picture) and that the only way to get rid of it is to switch to non 3D content.
    3D blu rays through PS3 play fine, as does the smart hub 3D content.
    Anyone facing the same issue or have I got a faulty TV?
  2. anorax25
    anorax25
    Oct 19, 2006
    1,102
    +141
    I've got the same model, I'll go have a look.
    Col.
  3. anorax25
    anorax25
    Oct 19, 2006
    1,102
    +141
    Sorry, no 3D content currently on BBC, will check later.
  4. ilovejaffacakes
    ilovejaffacakes
    Apr 20, 2012
    27
    +3
    Channel 217 on sky ' Eurosport' hours of coverage on there in 3d for nowt.
  5. anorax25
    anorax25
    Oct 19, 2006
    1,102
    +141
    I appreciate that but the OP said he was having trouble with BBC HD 3D.
  6. anorax25
    anorax25
    Oct 19, 2006
    1,102
    +141
    Klanker,
    Recorded a 3D program from BBC HD yesterday evening, plays fine. Still having problems?
  7. Klanker
    Klanker
    Jul 29, 2012
    2
    Still the same last night, unfortunately the only time I can check is the daily 11pm 3D highlight show! Will try again tonight to see what happens.
    anorax25 - are you using the built in freeview / freesat tuner or an external unit? I'm having the problem with the built in tuners.
  8. anorax25
    anorax25
    Oct 19, 2006
    1,102
    +141
    Hi Klanker,
    Aaah, I'm going through SKY. I will try the Freeview 3D connection tomorrow.
    Here's hoping it's not the TV.
    Col.
  9. anorax25
    anorax25
    Oct 19, 2006
    1,102
    +141
    Oooooh, hang on, it's not too late for that is it? I will check it now before the Horlicks!
    Col.
  10. anorax25
    anorax25
    Oct 19, 2006
    1,102
    +141
    Oh dear. Just checked mine via Freeview BBC HD and it's fine. Sorry mate, looks like you have an issue, if it's still the same at 23:07 July 30th.
    Forget the Horlicks, I'll have another small wine.
    Col.
