Samsung UE40h6400 Wall Mount
Discussion in 'Samsung TVs Forum' started by holtylufc, Jun 15, 2015.
Tags:
  1. holtylufc
    holtylufc
    Jun 15, 2015
    2
    doncaster
    Hi, Looking to wall mount my new Samsung UE40h6400 but i am unable to find the correct screws required to mount this.
    Can anyone confirm the screw size required?
  2. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    It should be in your manual under the VESA section. Do you have the manual? If not I'll dig mine out for you as I have the 48" version and believe it covered your model too.
  3. markgodley
    markgodley
    May 25, 2008
    6,864
    +2,469
    Here you go.
    Yours is the 40" I believe so you need m8 screws and they need to be between 20-21mm long (no bigger as you may damage the screen if they are too long)
    Hope this helps!
  4. holtylufc
    holtylufc
    Jun 15, 2015
    2
    doncaster
    Thanks that's brilliant
