Samsung UE40C7000WK Audio Problems
Transmecharian
Not sure if right place to post this if not can it be moved for correct help.
Anyway so I bought some new cambridge audio speakers and a sub that runs into an amp thats all fine its running on linear PCM but we wat to switch it to dolby but its grayed out and won't let us, any help were running through optical if you need more info to help ask away first post really.
toddy28
You will only get PCM sound from the optical output on the tv
Let me explain
From any external source it will only output 2 channel sound
Eg sky or DVD or built in tv tuner
It will out put 5.1 Dolby digital and dts when you use the media player to watch files with Dolby or dts sound
On my setup I have my sky linked via optical to my amp (sky does not pass through 5.1 through hdmi you have to use optical)
