Samsung UE32M5500 wall mount
Josh Bear
hi
Please can someone help. Just bought this TV 32m5500 for the kitchen and the screw holes in the back to mount on the wall are very recessed.
Anyone know how to wall mount this Tv? The box included black tubes that appear to fit in the tunnels down to the nut but no instructions as to what to do with them.
Josh
Josh Bear
Update I bought a large wall mount for another tv and that came with a set of various sizes of bolts and whilst one set is the right diameter the length isn't long enough for all the holes I.e. Two holes (top) are not a recessed as the bottom ones.
Are these sort of things available from screw fix?
