Samsung ue32k5100ak - help!
Discussion in 'Samsung TVs Forum' started by xZeinzu, Jul 22, 2018.
  1. xZeinzu
    xZeinzu
    Jul 22, 2018
    UK
    Hey, I actually managed to lose my remote, so I am unable to get onto settings. No luck on Google for a easy fix either.
    This TV only has 1 button. You press it once to bring up a short menu, slight hold to change option and hold down to select. I only get power, vol up, vol down, source and exit.
    That's all of the 'button combos' I know
    I have a USB stick that will connect my TV to wireless, so I could use an app on my phone as a remote. But, I need to go into settings to connect haha. Also, my phone has no infared either.
    I can just buy a fresh remote for £30 or a cheaper version for £20. But, before I buy, I really think there's a way around this so I'm just looking for help D:
    Thanks for your time for reading this anyway.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,997
    Lanarkshire
    +2,616
    There is no other way other than buying a remote to get into the settings.
