Samsung UE32F5000 wall mount issue
Discussion in 'Samsung TVs Forum' started by Johnsct, Sep 1, 2013.
Tags:
  1. Johnsct
    Johnsct
    Sep 1, 2013
    I have just bought a 32" Samsung LED full HD tv (UE32F5000) however immediately there is a massive problem:
    The bracket I have bought does not fit the TV despite samsung claiming it is VESA compatible...
    The issue is that my bracket comes with M4 and M6 screws which are not long enough or wide enough. Furthermore the holes in the bracket are also not as wide as the holes for the screws on the TV?
    Looking through the manual it states that the TV requires M8 Screws (Vesa spec 200x200mm) yet I have not been able to locate a bracket which supports this?
    I am looking for any help (preferably within the next week if you can) as to how to mount this TV on the wall or if anyone else who has bought this TV has any solutions?
    Thank you
  2. arenaman
    arenaman
    Nov 13, 2009
    8,347
    +6,814
    Thread moved
