I cant remember who I spoke to but the online version of the firmware is slightly behind what is put on the samsung support site. (Maybe only a couple of days delay - I dont know). Its easy to put on a usb and upgrade using that method. There is a download document to see exactly what you need to do. Plus its much quicker using the usb method.
ok thanks Kev.
My tv is wall mounted so will have to see how easily accessible the usb is.
Otherwise, may have to wait for the new firmware to become available via the tv.
My TV is very close to my router though and the wireless download speed for my last update was very quick, literally just a few minutes.
the usb is on the right hand side above the hdmi connections.
If you're flush against the wall you wont be able to access the USB connections, updates will have to be online only.
Hi guys,
my question is if the video proccessor on ES8000 is better or worse than the one on Marantz sr7007?
Simply put, would you advise me to pass on the video to the TV via CI+ directly from the sat-dish or go through (from the sat box) to the AVR receiver which is comming in this week.
My previous AV receiver caused me some HDMI handshake problems with the sat receiver so i moved the feed to the CI slot.
However the Marantz should not have these issues and I would move back if I notice improvements on SD and 720p broadcasting channels.
Any experiences or thoughts??
MG
Just got the 55es8000 to replace the 7000. New sw on. No banding or dss. I've got a good one. For those with banding it may be a fault and may be worth a swap.
Hello all, just bought myself a 65ES8000 and have to say what a great screen. I Had a 42' Panny PZ85B plasma before and I've no doubts this is going to match that once set up, which brings me to my question, can anyone recommend a good calibrator? The screen does great blacks (which I thought would be a weak spot) but does look a bit grey, I'm confident it can look stunning, with some help! Thank you
Ok, here we go again
Courtesy of "Garnoch" and "prsut" from the AVS forums. I've used these setings with Gamma at -2, Standard Colour tone and backlight at 14, sharpness I like around 35 too and AMP /eco sensor off.
The TV just looks better and better
10-27-12 STANDARD Update to counteract CE Dimming (whole screen dimming during dark scenes)
Picture Menu:
Mode: Standard
Backlight: To your liking, mine is 12 (3 or 4 lower than Movie mode)
Contrast: 97 (98
 before Firmware Update 1041.1)
Brightness: 53
Sharpness: 16
Color: 45
Tint: G50/R50
Screen Adjustment submenu:
Picture Size: Screen Fit (16 x 9 for TV if you don't want possible data visible on top or bottom, this will slightly zoom & degrade picture though)
Position: [no change]
Auto Adjustment submenu: [Grayed out]
3D submenu: N/A
Advanced Settings submenu:
Dynamic Contrast: Low
Black Tone: Dark
Flesh Tone: 0
RGB Only Mode: Off
Color Space: Custom
Color Space submenu:
Red: Red 50, Green 0, Blue 0
Green: Red 4, Green 48, Blue 4
Blue: Red 2, Green 6, Blue 46
Yellow: Red 52, Green 50, Blue 4
Cyan: Red 0, Green 50, Blue 51
Magenta: Red 40, Green 6, Blue 44
White Balance submenu:
R-Offset: 17
G-Offset: 17
B-Offset: 14
R-Gain: 5
G-Gain: 26
B-Gain: 20
10p White Balance: Off [grayed out]
Gamma: 0 (-2
Expert Pattern: Off
xvYCC: Off
Motion Lighting: Off [grayed out]
Black Enhancer: Off
Picture Options submenu:
Color Tone: Warm2
Digital Noise Filter: Off
 (Auto for DirecTV)
MPEG Noise Filter: Off
 (Auto for DirecTV)
HDMI Black Level: Normal (If available, set to Low for DirecTV or other STBs if picture looks light and cloudy)
Film Mode: Off or Auto 1 (When available)
Auto Motion Plus: Clear (Off can be less smooth - other settings give more Soap Opera effect and can stutter picture - personal pref)
LED Motion Plus: Off (On is suppose to help with fast motion - I have yet to see it make a difference)
System/ECO Solution:
ECO Sensor: ON
Minimum backlight level: To your liking, mine is now 5
Tried these settings last night wasn't very keen on them I think its the warm2 setting I cannot get used to - switched that to "standard" dropped the brightness down to 47 and kept everything else - I guess I don't like the picture so bright
Picture Menu:
Mode: Standard
Contrast: 97 (98
Brightness: 53
Sharpness: 16
Color: 45
Tint: G50/R50
3D submenu: N/A
Black Tone: Dark
Flesh Tone: 0
RGB Only Mode: Off
Color Space: Custom
R-Offset: 17
G-Offset: 17
B-Offset: 14
R-Gain: 5
G-Gain: 26
B-Gain: 20
Gamma: 0 (-2
Expert Pattern: Off
xvYCC: Off
Black Enhancer: Off
Color Tone: Warm2
 (Auto for DirecTV)
 (Auto for DirecTV)
ECO Sensor: ON
Tweaked my settings again at the weekend and finally very happy and settled .... so thats it, no more fiddling
You say that now. Look at my last post to arenaman
