Hi there! New here, but been lurking a lot.
I recently moved to Stockholm and I need a new TV! I´ve been researching the net like crazy and even went to a local store to check out TV´s but I´m still at a loss
That´s where you folks come in!
At the store every TV I looked at was phenomenal, so that didn´t really help me a lot, perhaps I´m just not picky. It´s my first HDTV after all anyways, I used to hook my xbox to a PC monitor, which worked well enough for me. But yes, I´d like a tv now because I look at movies a lot.
After reading thread after thread I found out that the Samsung has clouding issues and that the Panasonic has green blobs on the screen, and 50hz whatever that may mean bug. Not exactly what I was hoping to find :/
We have a D8000 at work (it was only a 46" though) and I noticed no clouding whatsoever... Ok there´s a little bit but who cares. Definitely not as bad as some pictures I´ve found on the net
I´m used to looking at my laptop screen, I don´t know what "black" really is
. I checked out the Panasonic (65" or something at the store) and the 3D was really, really impressive. Think it was better than the Samsung but yeah... I can deal with lighting inconsistencies but green blobs? Really? :s Even I would be able to notice that!
Is this really how you´re supposed to make your choice? "Ok, this TV seems to have less issues". Kind of disappointing at this price range.
Some info about me:
Will use the TV in a dimly lit room, will game on it, will watch movies often. And I love 3D, although there´s not that much content so that´ll only happen occasionally anyways. I don´t need the internet stuff...
The only difference between the 2 TV´s seems that the Panasonic has a better image quality + 3D but might suffer from flaws (green blobs, etc...). The samsung does not seem to have these issues, only the light bleeding which I´m pretty sure I can live with since I hardly noticed it on that D8000 at work. Both seem to have excellent response times so gaming should be excellent.
So yeah
? Everyone seems to like the Panasonic but I´m not sure I can live with the flaws. That´s why I was thinking: better safe than sorry... and go for the samsung which I´m pretty sure I´ll enjoy...
Anything I´m missing here? Could really use some advice on this one!
Thank you a lot!
Some info about me:
So yeah
Thank you a lot!
