Sizzle
Hi everyone,
I have a rather strange audio problem. I am definitely not an audio expert and hopefully someone can shed some light on this for me.
I am using a Samsung Smart TV (UN70TU7000BXZA) with the older Yamaha RX-V377 receiver. HDMI ARC is being used to connect them. Overall, the sound works, but I am running into some very annoying (and pretty much deal-breaker) issues that are puzzling me.
If I turn off both the TV and the receiver, and then turn them both on again, the sound setting on the TV automatically switches to internal "TV Speakers" and does not switch back to HDMI input. I have to manually go into the sound settings and select HDMI again. This happens every time, which is ridiculous. Once I select HDMI on the TV, there is still no sound, and I have to "cycle" the audio input on my receiver, by selecting a different input and then switching back to the correct one (AV4). Only then the sound works again.
Now, if I turn off only the TV and leave the receiver on, then when I turn the TV back on, its settings are fine and HDMI is selected correctly... but I still have the same stupid issue where I have to cycle the audio input (just like I described above) to something else and then back to the correct one.
It is so frustrating, and I have absolutely no idea how to tackle this. Could anyone provide any suggestions, or maybe someone has already dealt with this problem in the past? Any information at this point would be helpful.
Thank you very much in advance,
-Sizzle
-Sizzle
