I’m new to AV Forums but needing help if possible please. My set up is:
Samsung UE50TU8500
Shy+ HD box
Firestick 4k
All working fine, including HDMI CEC switching on TV when I switch on Sky. Then just before Christmas I introduced a Sonos Beam Gen 1 – still okay for about a fortnight, however lip sync wasn’t great. So I tried Optical rather than HDMI Arc, just the same. Back to HDMI Arc and found pass through, which fixed the lip sync issue. BUT the Sky box would no longer turn on the TV. I have tried very combination of soft reset/hard rest covering Sky box, TV and Sonos and nothing will bring back the auto switch on feature. This includes all the various settings within both Sky and my TV, including Input Plus, Anytime+, HDMI CEC etc.
So now I have to switch on Sky, use long press (which used to be short press) to turn on TV, then the Beam takes a while to start playing audio, longer than initially. I can use Alexa to adjust the Beam’s volume and to play music, but it WILL NOT switch the TV on or off. Throughout this, I’ve had some success where everything works for a few minutes, but switch off for an hour or so and the auto-switch on fails again.
I need ideas please! First, to bring back the HDMI CEC switch on feature. And/or, to use Alexa to switch on instead, which would probably do as a Plan B!
Any thoughts? I’ve replaced the HDMI cable between Sky and Samsung.
Thanks!!
Samsung UE50TU8500
Shy+ HD box
Firestick 4k
Thanks!!
