K
Kepler
I have a SAMSUNG CZ21A083NXXEU TV, and a question about volume control. When increasing or decreasing the volume, the banner that pops up on the screen shows the volume level by number. The problem is that while most times moving from one number to another leads to a small change in volume (as you would expect), the difference between level 4 and level 5 is quite stark, and the level that would suit me most for general watching is actually around the 4-and-a-half mark.
Is there any way of altering either the extent of change between these levels, of the volume of the base level. Essentially, is there anything I can do?
Thanks,
Thanks,
