Samsung TV & Sound bar questions
AccessShell
I have a Samsung UN50TU7000FXZA and Samsung sound bar HW-S50A. I am using an Digital Optical Cable to connect to the sound bar.
Some questions please.
1. Should the volume number show on the TV when the sound bar is used?
2. How do I know if the sound bar is turning off when I turn off the TV using the Cable remote?
3. The cable remote is paired with the TV. Can I get the cable remote to adjust the sound?
4. How can I reduce the background noise without affecting the dialogue?
cuke2u
You really need to connect the soundbar to the tv's arc hdmi port to answer most of those questions with a yes.
AccessShell
Thank you cuke2u. Right now I have no HDMI ports available. I am working on that.
I have been able to get the cable remote, the TV remote, and the Sound bar remote to adjust the volume.
Somehow I got the background noise to be hardly noticeable.
