Samsung tv no picture on dtv
Discussion in 'General TV Discussions Forum' started by gizaha, Jan 6, 2016.
  1. gizaha
    gizaha
    Jan 6, 2016
    4
    Greece
    Hello there. I have a problem with my samsung tv, le37s86bd
    I had problems with red and ghosty picture, i replaced t-con and now it's ok.
    I also have another problem (it was before replacing t-con). I have no picture on dtv, only audio*.
    This happens only on dtv, if i view through scart hdmi or anything external it works fine.
    The menu/gui works ok on dtv. It finds digital channels on search, but not have picture.
    *I'M NOT 100% PERCENT IF I HAVE AUDIO ON DTV because i have a problem in tv speakers that i'll fix tommorow.
    I tried factory reset from menu, reset from service menu, no result.
    So I suspect the digital receiver part. I would like to know exactly which part is on the main board.
    If someone knows something i don't know or can suggest a useful test to do, i would like to hear.
    Also please, in respect of the forum and others, if someone DOESN'T KNOW, i would appreciate to not post anything.
    Thank you.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,362
    Lanarkshire
    +2,514
    And...with respect to you...don't post until you're sure of the symptoms.
  3. gizaha
    gizaha
    Jan 6, 2016
    4
    Greece
    1 I explained that i have a problem with my speakers.
    2 It doesn't change the result.
  4. gizaha
    gizaha
    Jan 6, 2016
    4
    Greece
    New info.
    On external input (hdmi rca etc) i have both picture and audio.
    On analog tv i have both picture and audio.
    On DTV i have no picture, only audio. The dtv receiver doesn't seems dead, because it find the channels on search. Also the signal strength bar is near ~70-80%. Comparing the signal strength percentage with another tv i have in the same house, there are near similar numbers.
    I unsolder and remove the big emi shield. Underneath there were a lm317n (working) some capacitors, 2 bga chips etc. I don't know if dtv circuit is this, or if it's the other with emi shield, underneath the rf plug.
    Any ideas?
    Thank you.
  5. gizaha
    gizaha
    Jan 6, 2016
    4
    Greece
    Update.
    The tv seems to be mpeg2 compatible while in Greece we have mpeg4, thus the "sound only" problem.
