samsung th-tx500 won't turn on,help!
RustyRooy
My samsung th-tx500 just won't turn on,gutted because i've just wall mounted all the speakers & then a week later its broken!!!
any ideas guys or know anywhere to get it fixed?
thanks in advance......
Gaspode_TWD
Have you already tried the usual reset technique (disconnect from mains for a period)?
Try using a different socket for the mains and check the plug fuse. Any other fuses on it that might have blown?
RustyRooy
hi,
thanks for your reply...i've tried leaving the plug out for 12-24 hours & theres only one mains plug/so i think the fuse is fine as the red light still comes on!
maybe it just burnt out or something:(
Gaspode_TWD
Hmm ... So it just goes to standby? Unless you can find a stray wire which could be activating some protection circuitry (I'm particulary thinking speaker wires) I think its not going to be an easy home fix. Sorry.
RustyRooy
just fixed it,it was a loose connection in one of the main speakers..only after i unplugged it all aswell:)
Recovered
Hi RustyRooy,
Sorry for reviving this (and threadjacking!) but I have the same surround system as you and this thread was the only sensible thing I found when googling around for wall mounts. :)
Any chance you could share with me how you mounted the speakers?
Thanks in advance!
RustyRooy
Hi RustyRooy,
Thanks in advance!
i bought the wall mounts from ebay-Can post a link if still wanted?
