Samsung T100 data cable
Discussion in 'Mobile Phones Forum' started by highlanders, Jul 1, 2004.
Tags:
  1. highlanders
    highlanders
    Aug 24, 2000
    833
    Manchester, England
    +58
    I'm trying to unlock the phone and it came with a data cable for downloading ringtones and it seems I need a mbus cable to be able to unlock the phone, are they one in the same thing?
  2. StevieDvd
    StevieDvd
    Dec 27, 2003
    1,378
    Stevenage, Herts
    +151
    It's a long time since I used my T100 but I recall the cable it came with was fine for unlocking, it was unlocked by the guy I bought it from and I think he used the standard cable. I reflashed the software later myself - you can replace the screens, menus etc.
    Some avid googling should find the details.
  3. highlanders
    highlanders
    Aug 24, 2000
    833
    Manchester, England
    +58
    Yes you are correct, just done the deed why do I think I'm breaking the law by unlocking a phone I know I'm not.
