Samsung SWA-4000 - No Sound !!!
Discussion in 'Home Cinema Buying & Building' started by sideshowbob32, Feb 1, 2009.
  1. sideshowbob32
    sideshowbob32
    Feb 1, 2009
    5
    Hi All!!
    I have just purchased a Samsung SWA-4000 Wireless Transmitter to go with my Samung HT-X30 Home Cinema & Samsung LE32R88BD TV :).
    The home cinema works fine with the TV but there is no sound from the two wireless speakers :confused:. I've inserted the TX card into the home cinema, the blue 'link' light on the transmitter is on, but there is still no sound! I have the settings on the home cinema set to 'Pro Logic' but still no joy!
    On the LCD display on the home cinema only L,C,R & SW are lit up, there is no RR & LR! I have googled the subject, and all I have found is 0,1,3,5 to reset the system, but that didn't work either!
    Does anybody have an idea what the problem is? Thanks in advance!:thumbsup:
    Rob
  2. sideshowbob32
    sideshowbob32
    Feb 1, 2009
    5
    Anybody??
  3. Deputy Dawg UK
    Deputy Dawg UK
    Jan 9, 2006
    1,478
    Rushden, Northants
    +58
    I was thinking of getting one of these when I get my new surround sound systeme this week..maybe not :(
  4. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    Go into the amps menu and select 'yes' for the rears
  5. nobby1963
    nobby1963
    Mar 3, 2008
    441
    28
    +41
    Also the sound mode needs to be at `matrix` if you are not getting the sound from a 5.1 source. Have you an optical connection to your sound source - tv or sky+ or sky hd ?
  6. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    Sometimes fitting these wireless units knocks the rears out, so just need to re-setup in the menu, many of the same problem posted here in the past
  7. sideshowbob32
    sideshowbob32
    Feb 1, 2009
    5
    The setting is set to Matrix, no Sky or Sky HD just freeview built into the TV. I called Samsung they say the unit may be faulty, but the guy seemed clueless on the phone (much like myself). He didn't mention anything about the amps menu how do I access this?
  8. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    1 In Stop mode, press the MENU button.
    2 Press the Cursor button to move to <Audio> and then press the ENTER button.
    3 In the <SPEAKER SETUP>, press the ENTER button again.
    4 Press the Cursor , , , button to move to the desired speaker and then
  9. sideshowbob32
    sideshowbob32
    Feb 1, 2009
    5
    Your a legend! It works great now thanks very much :thumbsup:! Those guys at Samsung customer service are muppets
  10. kentish_lad
    kentish_lad
    Sep 14, 2006
    1,627
    Kent
    +192
    Glad you sorted it mate:smashin:
  11. mariesher74
    mariesher74
    Mar 7, 2009
    2
    I need help. I have a samsung HT TZ315 home cinema system. problems from day 1. When playing a dvd could hear through all speakers but couldnt hear sky through any. Called samsungs so called helpline and they said faulty unit, useless and cleless! Sky came out to change my box to HD and sorted it for me within 5 mins. Although I still couldn't view sky through the rear speakers. Been waiting since December for my SWA 4000 which finally came last week. After following the directions it won't link up. The blue light continually flashes and then the standby light comes on. Meanwhile the DVD display keeps saying REAR CHK. The manual is pretty useless so I phoned Samsung but once again they were rude and clueless. They are saying the unit is faulty and needs to be repaired. But given that that was their advice last time I don't have much trust in them. Can anyone help?
    I have tried to do the test tone but it is no longer registering that the rear speakers are present.
    I have no faith in samsung at all now!!
    Please help!
  12. sideshowbob32
    sideshowbob32
    Feb 1, 2009
    5
    This worked for me, once your rear speakers have been turned on you will no longer get the check rear error message on your surround sound and you will have sound from your rea speakers
  13. mariesher74
    mariesher74
    Mar 7, 2009
    2
    Thanks. I tried that but it is no longer recognising that there are any rear speakers so won't allow me to turn them on. I can't get the wireless module to form a link. :confused:
