Samsung SV-DVD440 is there a hack?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by Return of Bruno, Dec 16, 2004.
  1. Return of Bruno
    Return of Bruno
    Apr 23, 2004
    121
    +16
    Was thinking of buying this dvd/vcr deck for my mum. Is there a region hack for it?
  2. azzurro
    azzurro
    Here you go, it works 100%, just did it on mine.
    All operations are achieved from the remote control.
    1. Power on the system with an empty tray, it will display "No Disc".
    2. Press the SUBTITLE key and then press 57538. It will display the current region setting.
    3. Select the desired region setting (9=region free, 1=region 1, 2=region 2, ...).
    4. Confirm the choice by pressing the SUBTITLE key.
    5. Power down the system. (this step may not be necessary:not tested)
    At your next power on, the system will be set to the desired region setting.
