@desinho
Input lag 38ms in game mode.
Uniformity isn't great (could be a bad review sample?).
Mentions rather large dimming zones but doesn't say how many.
Contrast ratio measured at 2937: 1.
Calibration out of the box so good they didn't see much need for calibration.
Their conclusion, scoring 8 out of 10 - wonder if the rating would raise now as test price was €2,400? (Google Translate so not perfect):
The JS8000 is a high-end model and that is well reflected in the design of the housing. Thanks to the metallic finish exudes luxury from the TV. The straight base fits well with the flat screen, but the use of plastic is not as nicely finished as the housing. Thanks to One Connect Mini you do not have to be behind the TV if you need to connect a cable. That of course is only an advantage if you frequently need to connect anything but a side benefit of this break-outbox is that no connections straight mounted back on the TV, which is handy if you want to wall-mount the unit.
The operation is nice and smooth, thanks to the Tizen OS. You get two remotes at which both work well.Smart Control is handier when operating apps and can also be used as a universal remote control but for regular TV viewing, we prefer the infrared remote control because it has more buttons. Actually it would have been more convenient if Samsung, like LG, the two separate remotes into one device had united.
In terms of image quality, the JS8000 is doing well, as you would expect from a high end model. The contrast is a LCDTV fine and the color reproduction is very good without you there first before having to calibrate. All you have to do after you get the TV out of the box, choose the preset film, after which you can enjoy beautiful uhd images. Minus to the picture quality regards the uniformity of the image. The brightness is quite uniform, but when displaying images of uniform, there is shown what difference in color temperature. Luckily the vast majority of images barely.
The sound is good thanks to the smart, narrow openings below the screen, making it directed towards your ears. Because the openings relatively close together, the stereo image would be better, but otherwise the audio system is performing better than average, with a fairly good bass and undistorted viewing of the somewhat higher volumes.
We are not in favor of curved screens for televisions, mainly because they pose disadvantages and so we were sorry that Samsung had with the introduction of the S-uhd models chosen to create a single curve models. Fortunately, the Korean electronics giant returned to this decision. The JS8000 is not a cheap TV, but offers great value for money and barely knows downsides. We hope that Samsung will offer the JS8000 also in other sizes, for those who find 55 inch too big or too small.
