Samsung SP50L7HXX Service Menu
Discussion in 'TVs' started by aftertaste, Mar 25, 2005.
  1. aftertaste
    aftertaste
    Mar 16, 2005
    1,176
    +95
    Due to some picture proboems I'm having I'd like to get into the service menu to see if using the "factory reset" cures the problem. Using the "Mute, 1, 8, 2, power" method that I've read in several places won't work though. Is there another code I can try? Or some other way into the service menu? What might I be doing wrong? I also tried another sequence of buttons that won't work.
    Any help gratefully received!
  2. DIMA NETU
    DIMA NETU
    Jan 9, 2005
    40
    When TV of. 1.Info 2.Menu 3.Mute 4.Power
    I read about your problem. It is a lot of adjustments for color In the service menu . Not having the service manual's it is possible to make even worse. Goog luck!
  3. aftertaste
    aftertaste
    Mar 16, 2005
    1,176
    +95
    Where did you read about this problem? I'd be interested to take a look myself. What did it say was the solution?
    I also saw the "info, menu, mute, power" way to access the service menu, but I can't make it work.
  4. DIMA NETU
    DIMA NETU
    Jan 9, 2005
    40
    Sorry my English, I read your post about it in this forum. About service menu-try do pushing to buttons fast. It works. I have the same TV model.
  5. aftertaste
    aftertaste
    Mar 16, 2005
    1,176
    +95
    Well, I've tried entering the service menu in every way I can, and no matter what speed I press the buttons, it won't work. What could I be doing wrong?
  6. DIMA NETU
    DIMA NETU
    Jan 9, 2005
    40
    Turn Melody off in the user menu, may be it helps. My TV has firmware: T-CLPPEU-1030 Release time: Dec. 16 2004
  7. aftertaste
    aftertaste
    Mar 16, 2005
    1,176
    +95
    The melody was already off
  8. DIMA NETU
    DIMA NETU
    Jan 9, 2005
    40
    My TV has Model Code SP50L7HXX/BWT made in Korea
  9. DLPGirl
    DLPGirl
    Does anybody knw Where to acess the Colour, Brighness and sharpness options all my efforts are in vain so far :(
  10. DLPGirl
    DLPGirl
    Comeon surely somebody must knw!!!!! All the sammy owners help a girl out :lease:
  11. Stingingwasp
    Stingingwasp
    Mar 17, 2005
    72
    HI DLP Girl,
    Press the Menu button and go to Picture settings. Select the "Custom" option (2nd one down) and this will take you to the picture settings.
    Hope this helps.
  12. JZEE
    JZEE
    Jan 8, 2005
    I also cannot access the service menu on my SP46 via the info-menu-mute-power combo. Any ideas please, I'd really like to see how much hours are on the bulb.
  13. bob_renkus
    bob_renkus
    I have the SP-50L6HX and the <Info.Menu.Mute.Power> does bring you to service menu. But there is a catch: you can only do this when the lamp unit is complete shut-off. If the unit is already up, put it back on stand-by but wait till the lamp is shut (screen goes completely dark) or better yet do it on your first power up. That should work (at least for mine). ;)
  14. JZEE
    JZEE
    Jan 8, 2005
    Its strange as on powering the TV up on the first time, mine goes to stand-by for about 2 seconds and then switches on automatically - it does not stay in stand-by :confused:
