Samsung SP50L7HX Box size!
Discussion in 'General TV Discussions Forum' started by Beef, Mar 18, 2005.
  1. Beef
    Beef
    Feb 28, 2005
    24
    3
    Wife just got back from cebit (gutted I didnt get to go :thumbsdow ) and she brought back the samsung DLP brochure and it contains the box size.
    Box (W x H x D, mm) 1485 x 1530 x 646
    TV 1361 x1389 x 520
    Hope this info helps - definetly going to be a tight fit with my front door
  2. mistycat
    mistycat
    From experience, if you take it out of the box in your front yard, this can work nicely, as it is quite easy to move once the box is off. The second box problem is getting it off and out of the room! I talk from experience here!!
  3. Beef
    Beef
    Feb 28, 2005
    24
    3
    just hoping its not raining the day they deliver it!
